The Duet range of controller boards has a number of outputs to directly connect heaters. These are supplied by VIN voltage, i.e. the voltage of the PSU that powers the Duet, and are generally protected by a fuse. Mainboards usually have one 15A output, primarily intended for a 3D printer heated bed, and two or three (depending on board) 6A outputs, primarily intended for a 3D printer's extruder heaters. See the wiring diagram for your board for specific information and wiring. Additional heaters can be controlled by adding expansion boards, and/or by using PWM outputs on board to control Solid State Relays.
Heater outputs can also be used for other applications, e.g. CNC spindle control, laser cutter/engraver control, pumps and other electric motors that draw more current or require a higher voltage signalling level than other PWM pins on the board can support.
| Board | 'Bed heater' output | 'Extruder heater' outputs | RRF3 pin name | RRF2 heater number |
| Duet 3 Mainboard 6HC | 1 x 18A (15A fuse) | 3 x 6A | out0 (bed), out1, out2, out3 | - |
| Duet 3 Mini 5+ | 1 x 15A (15A fuse) | 2 x 5A | out0 (bed), out1, out2 | - |
| Duet 3 Expansion 3HC | - | 3 x 6A | out0, out1, out2 | - |
| Duet 3 Toolboard 1LC | - | 1 x 5A | out0 | - |
| Duet 2 WiFi/Ethernet | 1 x 18A (15A fuse) | 2 x 6A | bedheat, e0heat, e1heat | 0 (bed), 1, 2 |
| DueX2 and DueX5 | - | 2 (DueX2) or 5 (DueX5) x 6A | duex.e2heat to duex.e6heat | 3 to 7 |
| Duet 2 Maestro | 1 x 18A (15A fuse) | 2 x 6A | bedheat, e0heat, e1heat | 0 (bed), 1, 2 |
Note that some boards are rated to 18A on the bed heater channel. However, all Duets are supplied with a 15A fuse fitted (18A fuses are difficult to source). If you need 18A on the bed heater channel then you need to fit a 20A fuse and take further precautions against over-current. This rating has been increased from 15A due to updated thermal testing.
RepRapFirmware has some limits on how heaters can be configured. As of RRF 3.7 these are:
| Duet 3 MB6HC/6XD | Duet 3 Mini 5+ | Duet 2 WiFi/Ethernet (RRF 3.6) | Duet 2 Maestro (RRF 3.5) | Notes | |
| MaxHeaters | 32 | 32 | 10 | 4 | The maximum number of heaters |
| MaxPortsPerHeater | 3 | 2 | 2 | 2 | The maximum number of output ports per heater |
| MaxMonitorsPerHeater | 3 | 3 | 3 | 3 | The maximum number of monitors per heater |
| MaxBedHeaters | 12 | 4 | 4 | 2 | The maximum number of bed heaters |
| MaxChamberHeaters | 8 | 4 | 4 | 2 | The maximum number of chamber heaters |
| MaxHeatersPerTool | 20 | 8 | 8 | 2 | The maximum number of heaters per tool |
In RRF 3.7 and later, each bed heater slot and each chamber heater slot can use up to 4 heaters (see M140 and M141).
See the following sections for more detail on connecting and configuring heaters:
Connecting and configuring extruder heaters
Connecting and configuring a bed heater
Connecting and configuring a chamber heater
Tuning the heater temperature control
Note that while it's possible to configure a heater with no temperature control, for safety all heaters should have a temperature sensing channel associated with them. The Duet series supports 4 types of temperature sensor: thermistor and PT1000, thermocouple, and PT100. For more details see Choosing temperature sensors.
