Image from www.flickr.com
Most 3D printers have very few sensors, and all sensors are fallible, so sometimes a 3D printer will start behaving in an uncontrolled way. Although the Duet Web Interface has an Emergency Stop button, it can be valuable to have a physical button attached to the printer. Traditionally robots use a big red mushroom so it's easy to hit even if, say, your arm is trapped in the robot. But there are several grades of "stop" one could accomplish.
Note that a true "emergency" stop should cut the power, external from any electronic and firmware control - the big red button illustrated for example
The most definite way to stop a robot is to cut all power to it. Yanking the plug out of the wall works, as does a circuit breaker that's easy to flip by hand, or a Residual Current Device (RCD) whose test button is easy to press. This will cut all power regardless of any component failure aboard the Duet or robot. Of course it requires a physical action to reset.
Executing GCode M112 causes any moves in progress to be immediately terminated, then Duet shuts down. All motors and heaters are turned off. However, your PSU will continue to run.
If your power supply is controlled by the PS_ON pin of the Duet, executing M112 does NOT shut down the 12/24V circuit. If you want to turn off the PS_ON pin using an external trigger, consider writing a macro that turns it off via M81 before it calls M112; see "Making a button do what you want" below.
Note that turning off the PSU will make your "always-on" fans turn off even though your hot end may be hot, and it also leaves the head wherever it was when you stopped the machine. The former might produce a hot end jam, and the latter might heat the bed. Also, if your axes are smooth enough, turning off the stepper motors entirely may allow the machine to fall. On the other hand, one of the ways for the MOSFETs controlling the heaters to fail is for them to fail shorted, so that the heaters are on 100% regardless of what the MCU commands; shutting off the 12/24V supply will shut them off in spite of this.
If the machine's misbehaviour is mild, you may want to stop what it's doing but not shut everything down. You can write your own G-code macro for what should happen in this case, for example, turn off all heaters and home the head. At the moment, there is no way to make this interrupt actions in progress (including "wait for heater to reach temperature").
The Duet firmware allows you to associate a state change on any endstop with a "trigger", a user-definable action, with the M581 G-code. Trigger 0 does an emergency stop (like M112), Trigger 1 pauses the print, and any higher number n executes the file triggern.g. So you can arrange for a physical button to execute any command by connecting it to the pins of an unused endstop.
Note that triggers only fire on a transition off -> on; you can use M582 to make the trigger fire if the button is already pressed. You can use M574 to select whether the button is normally open or closed.
The easiest way to implement an external reset/emergency stop, is to configure it as an External Trigger using M581.
Duet 3: Connect to any available IO connector, between 3.3V and IO_x.in.
Duet 2: You can use any free endstop connector on the Duet. If you don't have a DueX board connected to the expansion connector, you can use any of the five En_STOP pins (n = 2-6). They are labelled on the underside of the Duet.
The forced emergency stop using the easiest method is setup inside your config.g file as follows.
RepRapFirmware 3.x requires a pin definition with M950 before setting the trigger with M581:
;Duet 3
M950 J1 C"io4.in"
;Duet 2
M950 J1 C"e1stop"
M581 P1 T0 S1 R0
The parameters:
M581 T0 E1 S1 C1
The parameters:
If the switch is reliable and works as expected, you can add a check for an external trigger with M582 inside your config.g - useful if you need the button to be reset before the Duet can restart (useful if using the PS_ON features).
Pressing the "Emergency Stop" switch within Duet Web Control or sending M112 also reset the board. this can be useful however are not a direct substitute for a hardwired emergency stop that cuts the power.
