Duet Software Framework (DSF) is the bundle of software programs running on the Raspberry Pi that connects to and controls the Duet 3. This page covers installing DSF on a custom Debian board/installation (such as plain Raspberry Pi OS on a Raspberry Pi or Armbian on other boards).
Please follow these steps to prepare your board for a DSF link.
In order to use DSF, you must have a board that supports ARMv7 instructions. Make sure the board has a 32 or 64-bit Debian-based distribution installed before you continue.
DSF has inofficial support for RPM and Arch-compatible packages but they are not actively maintained, which means you have to build them on your own if you wish to use them. See the build instructions on how this can be done.
DSF uses an SPI link to communicate with a Duet. Before you can enable the communication between both devices, you must ensure an SPI channel can be opened.
To provide a controller base for the Duet, the first SPI port on the Linux controller board is used. If Raspbian operating system is used, the SPI driver can be enabled by doing the following steps:
Run
sudo raspi-config
(Alternatively sudo raspi-config nonint do_spi 0 will enable SPI with a single command)
Navigate to Interface options
Go to P4 SPI
Confirm to enable the SPI interface
This will ensure the SPI driver is loaded and Duet Software Framework can use it for communication to the Duet board. To confirm that this step worked, run
ls /dev/spidev*
and verify that /dev/spidev0.0 has been created.
Please check the documentation of your board about how to enable SPI. This usually varies per vendor. When enabled, keep track of the SPI device node, it will be required later.
Note that the following steps are not required if you are already running DuetPi.
Apart from the following two package feeds, there are a few more version-dependent feeds available. See the dev wiki for further information.
To obtain the required software packages on a Debian-based distribution running an ARMv7 processor (RaspPi 3 or newer) execute the following commands:
wget -q https://pkg.duet3d.com/duet3d.gpg
wget -q https://pkg.duet3d.com/duet3d.list
sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/
sudo mv duet3d.list /etc/apt/sources.list.d/duet3d.list
sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg
sudo chown root:root /etc/apt/sources.list.d/duet3d.list
Once this is done, install HTTPS support for APT, update the package feeds, and install the DSF bundle:
sudo apt-get install apt-transport-https
sudo apt-get update
sudo apt-get install duetsoftwareframework
If you wish to use the latest unstable/beta DSF components, you can run the following commands instead:
wget -q https://pkg.duet3d.com/duet3d-unstable.list
sudo mv duet3d-unstable.list /etc/apt/sources.list.d/duet3d.list
sudo apt-get update
Please be aware that the unstable repository is meant for beta testers and that it can contain experimental code. For production use, the stable repository is strongly recommended.
If your SBC is not connected to the internet, you can download the .deb packages for DSF and install them offline.
dpkg -i *.deb from the directory where the .deb files are located.sudo dpkg -i /boot/*.deb.dpkg will tell you.(See this forum thread for more info.)
DSF needs support for bigger transfers than the default maximum 4096 bytes. For this reason the buffer size of the SPI module has to be increased. This can be achieved by creating a new file /etc/modprobe.d/spidev.conf using the following command:
echo "options spidev bufsiz=8192" | sudo tee /etc/modprobe.d/spidev.conf
It is required to reboot the device once this step is complete.
If you are using a different board than the Raspberry Pi and if your SPI device node is not /dev/spidev0.0, you must change it next. To do so, open /opt/dsf/conf/config.json and edit the value of SpiDevice accordingly.
The link between Duet and SBC requires an extra GPIO pin so that the Duet can flag when it is ready to exchange data. This port defaults to pin 25 on the Raspberry Pi 3 and 4. Furthermore, DSF uses libgpiod to access this pin.
The following steps are not required if a Raspberry Pi is used.
Most Linux distributions provide a toolkit for the gpiochip module in a package called gpiod.
You must have this package installed (containing the gpioinfo program) before you can continue.
In order to identify the GPIO device and pin number for DSF, run the gpioinfo command to get a list of available pins.
On a Raspberry Pi, the output will provide something like
gpiochip0 - 58 lines:
line 23: "GPIO23" unused input active-high
line 24: "GPIO24" unused input active-high
line 25: "GPIO25" unused input active-high
line 26: "GPIO26" unused input active-high
line 27: "GPIO27" unused input active-high
In this default scenario, GPIO25 corresponds to pin 22 of the expansion header on the Raspberry Pi. That means DSF can use pin 25 from /dev/gpiochip0.
Note that the output of gpioinfo may vary and for other SBCs it may not be as verbose as seen here. Refer to the manufacturer documentation of your SBC for further details. When you connect +3.3V to the pin of your choice, it may help to use the gpioget utility to find the actual chip device and pin number:
pi@Duet3:~ $ gpioget gpiochip0 25
1
where 1 corresponds to a high level (+3.3V) and 0 to a low level (GND).
When you have identified the correct chip device and pin number, open /opt/dsf/conf/config.json and change the values of GpioChipDevice and TransferReadyPin accordingly.
It already defaults to pin 25 for the Raspberry Pi, so you can skip this step if you are using one.
DSF 3.3 and later allow the installation of third-party plugins on the SBC. To prevent regular plugins from performing malicious actions, they are confined using AppArmor security profiles.
This means AppArmor support must be enabled before third-party plugins can be installed.
To achieve this on a Raspberry Pi, perform the following:
apparmor packagelsm=apparmor to it (for Raspberry Pi this is saved in /boot/firmware/cmdline.txt)aa-status and check the output)Note it is also possible to disable the AppArmor requirement for Linux distributions that do not support it (like RedHat-based distros), but this is not encouraged and a potential security hazard. To do this, edit
/opt/dsf/conf/plugins.jsonand setDisableAppArmortotrue.
This section describes the required services/components for DSF.
Now you have installed Duet Software Framework, but none of the services has been started yet. As a first step, it is important to start the main application of DSF called Duet Control Server. To do this, make sure you have the Duet 3 connected to your Linux board via the ribbon cable and run
sudo systemctl start duetcontrolserver
This should complete without an error. If it fails, check why it did so by running
sudo journalctl -u duetcontrolserver
To make it start automatically on boot, run
sudo systemctl enable duetcontrolserver
If you wish to change parameters of the DCS configuration, edit /opt/dsf/conf/config.json. To revert to factory defaults, you may delete this file as well and restart DCS. In this case, DCS will restore it automatically.
Once DCS has been started, you can start the web server which provides the web interface. This can be achieved by running
sudo systemctl start duetwebserver
If that fails for some reason, run
sudo journalctl -u duetwebserver
to figure out why. Once it has been started, you can make it start on boot as well by running
sudo systemctl enable duetwebserver
Note: The webserver defaults to ports 80 (and 443 if TLS is enabled, see M586). You must change them in
/opt/dsf/conf/http.confif you wish to use different port numbers.
For your convenience, Duet Web Server serves the user interface, Duet Web Control, from the /www folder of the virtual SD card directory (see below). This effectively mimics the old behaviour of previous Duet controllers. Once DWS has been started, open a browser of your choice and go to http://127.0.0.1. If you do not wish to connect manually every time you do this, you can specify the hostname of your Linux board instead of 127.0.0.1 as well (e.g. rasperrypi on Raspbian).
If you wish to use the DuetPiManagementPlugin that provides support for several extra M-codes for system management, you must start the plugin services next. You can make them auto-start on boot by running:
sudo systemctl enable duetpluginservice
sudo systemctl enable duetpluginservice-root
and to start them right away:
sudo systemctl start duetpluginservice
sudo systemctl start duetpluginservice-root
After these you should be able to manage and install third-party plugins using DWC.
When your setup is complete, have a look at the regular guide for further information about upgrades and the virtual SD card.
Please see the SBC Setup Guide for further information.
