work in progress, will be changed often to change to screw theory and geometric algebra solution
Following is a description of the common 6 axis industrial robot. It has the following axes:
The basic configuration setting is
M669 B"robotType=6Axis"
6 axis robots are capable to control all 6 degrees of freedom (6DOF).
The configuration page describes the code to setup the robot, the screw theory page describes how axes' properties are specified.
For the 6 axes, the letters XYZABC are used, all axes being rotary axes, referenced in the document as axes 1 to 6. The arms are referenced as arms 1 to 6, being behind the axes (e. g. arm 2 is between axis 2 and 3).
IJK is not usable, as IJ is used for G2/G3 code.
Care must be taken when the robot is powered off: the arms need protection against falling down with damaging result. The following possibilities avoid it
Kinematics uses the G10 settings of the currently selected tool.
The following setups were used to test forward and inverse kinematics, so if one uses this configuration, chances are good that the robot works correctly.
This is the setup of the DH example, with the change that axes 1 and 2 intersect.
To ease calculation and make intersection clear, 1-2 and 4,5,6 are set to same point each. The points need to be somewhere on the axis.
Axis 3 can be X, Y offset from 1-2 also for the kinematics to work correctly and it doesn't need to be parallel to axis 2.
| axis # | direction | a point on the axis |
| 1 | 0, 0, 1 | 0, 0, 352 |
| 2 | 0, 1, 0 | 0, 0, 352 |
| 3 | 0, 1, 0 | 0, 0, 712 |
| 4 | 1, 0, 0 | 380, 0, 712 |
| 5 | 0, 1, 0 | 380, 0, 712 |
| 6 | 1, 0, 0 | 380, 0, 712 |
tool: z = length 100 set with G10
GSt(0) must be the tool tip pos/ori
GSt(0), endposition for given angles/positions (rotary/prismatic):
| direction | value |
| x | 0, 0, 1 |
| y | 0, -1, 0 |
| z | 1, 0, 0 |
| pos | 545, 0, 712 |
| angles/pos | 0, 0, 0, 0, 0, 0 |
angle limits:
| axis | angle min | angle max | homing angle |
| 1 | -150 | 150 | 0 |
The workspace is ...
singularities are at...
