Some Duets support 12864 mono graphics LCD displays with a rotary encoder.
There are two types of controller chip commonly used in these controllers: ST7920 and ST7567. Some Duets support one or both of these types - see below for details. Both types use a menu system stored on the SD card. See 12864 display menu system.
Certain board versions have different methods of controlling the backlight on these boards.
| Duet | ST7920 | ST7567 | Notes |
| Duet 3 MB6HC/6XD | N | N | |
| Duet 3 Mini 5+ | N | Y | |
| Duet 2 Maestro | Y | Y | ST7567 Requires modified wiring loom |
| Duet 2 WiFi / Ethernet | N | Y | ST7567 Requires modified wiring loom |
Duet 3 Mini 5+ provides two 2x5 ribbon cable headers for connecting a compatible ST7567-based controller (see below).
We do not recommend connecting a 12864 display with ST7920 controller directly to the Duet 3 Mini 5+ because the 3.3V signals provided by the Duet 3 Mini do not meet the specifications of the ST7920 controller chip when it is powered from 5V. If you do wish to try it, you will most likely have to reduce the clock frequency (M918 F parameter) to get it working at all, and it may not work reliably. Also, note that when configured for 12864 display with ST7920 controller, RepRapFirmware provides the CS signal on the pin normally used for A0 because that more closely matched the pinout of typical 12864/ST7920 displays.
User PCR on the Duet forum has created a level-shifting board that plugs into the Mini 5+, and converts the 3.3V signalling to 5V, allowing ST7920-based displays to be supported. See this thread on the forum.
The Duet 2 Maestro provides two 2x5 ribbon cable headers for a 12864 display using ST7920 controller. The connector pinout is compatible with the original RepRapDiscount design. There is also more information in this thread on the forum.
RepRapFirmware 3.2 and later also support displays using the ST7567 controller. For these displays, use the standard cable EXCEPT the following two wires need to be connected to the EXPANSION header pins:
| Duet 2 Maestro output | Display input | Function |
| Expansion pin 4 (EXP_0) | EXP 1 pin 7 | LcdA0Pin |
| Expansion pin 5 (EXP_1) | EXP 1 pin 8 | LcdCSPin |
RRF 3.5 and later: NeoPixel support may work in RRF 3.5 on the Duet 2 Maestro. However, this has not been tested by Duet3D. The maximum number supported would be limited by available RAM.
RRF v3.4.5 and earlier: The Duet 2 Maestro does not currently support the M150 command for controlling addressable LEDs/NeoPixel backlights, because Maestro is very short of spare outputs. Displays with a fixed backlight should work, e.g. Fysetc Mini12864 Panel V1.2 (NOT V2.0 or V2.1), but have not been tested.
RepRapFirmware 3.2 and later support a 12864 display using ST7567 controller. RepRapFirmware 3.3 added support for a short string of NeoPixels on Duet WiFi and Ethernet, so boards that use a NeoPixel for the backlight should be able to be controlled. See this thread on the forum for more details.
You will need to make up your own wiring loom, connected as follows:
| Duet 2 WiFi/Ethernet output | Display input | Function |
| CONN_LCD pin 2 | EXP 1 pin 2 | gnd |
| CONN_LCD pin 3 | EXP 2 pin 6 | EncoderPinB |
| CONN_LCD pin 4 | EXP 2 pin 8 | EncoderPinA |
| CONN_LCD pin 5 | EXP 1 pin 5 | LcdNeopixelPin |
| CONN_LCD pin 6 | EXP 1 pin 6 | LcdResetPin |
| CONN_LCD pin 7 | EXP 1 pin 7 | LcdA0Pin |
| CONN_LCD pin 8 | EXP 1 pin 8 | LcdCSPin |
| CONN_LCD pin 9 | EXP 1 pin 9 | EncoderPinSw |
| CONN_LCD pin 10 | EXP 1 pin 10 | LcdBeepPin |
| CONN_SD pin 1 | EXP 1 pin 1 | +5V |
| CONN_SD pin 2 | EXP 2 pin 2 | gnd |
| CONN_SD pin 3 | EXP 2 pin 7 | SD CS |
| CONN_SD pin 4 | EXP 2 pin 9 | sck |
| CONN_SD pin 5 | EXP 2 pin 5 | mosi |
| CONN_SD pin 6 | EXP 2 pin 10 | miso |
We do not recommend connecting a 12864 display with ST7920 controller because the 3.3V signals provided by the Duet 2 WiFi/Ethernet do not meet the specifications of the ST7920 controller chip when it is powered from 5V. If you do wish to try it, you will most likely have to reduce the clock frequency (M918 F parameter) to get it working at all, and it may not work reliably. Alternatively, use a level-shifter to convert the 3.3V signalling to 5V.
These displays are typically clones of the RepRapDiscount Full Graphic Smart Controller and look like this.
The ST7920 controller chip is invariably powered from 5V, which means that the display needs 5V input signal levels. The better ones include a contrast adjustment potentiometer.
With the display connected, menu files need to be added to the SD card, or the display will have nothing to show. See 12864 display menu system.
To configure this type of display in RepRapFirmware, use the M918 command with display type parameter P2. The contrast setting for these displays is done in software, and the M918 command supports a C parameter for this purpose. It may also be necessary to set a resistor ratio parameter in software, which can be done using the M918 R parameter.
For displays with NeoPixel RGB LED backlights, the configuration depends on which firmware version you are running. RRF 3.5 and later uses M950 to configure the LEDs, and M150 to control them. RRF 3.4 and earlier uses M150 to both configure and control LEDs. These commands will usually be added to the config.g, so the display is enabled at startup.
From RRF 3.5.0, M950 is used to configure displays that support NeoPixel RGB backlights, and M150 is used to control the LEDs.
Example for Fysetc Mini12864 V2.1 display with NeoPixel LEDs on a Duet 3 Mini 5+ 12864_EXP1 connector:
M918 P2 E-4 F2000000 ; Fysetc 12864mini
M950 E1 C"io3.out" T1 U3 ; create an RGB NeoPixel LED strip with 3 LEDs on the Duet 3 Mini 5+ 12864_EXP1 header
M150 E1 R0 U0 B255 P255 S1 F1 ; display LED blue
M150 E1 R255 U0 B0 P255 S1 F1 ; left encoder LED red
M150 E1 R0 U255 B0 P255 S1 F0 ; right encoder LED green
Example for Makerbase MKS Mini12864 V3.0
M918 P2 E-4 C70 R4 ; enable MKS Mini12864
M950 E0 C"io3.out" T1 U3 ; create an RGB NeoPixel LED strip with 3 LEDs on the Duet 3 Mini 5+ 12864_EXP1 header
M150 E0 R255 U0 B0 P255 S3 F0 ; GRB LEDs so this shows green
Note that some RGB LEDs define their colours in the order Green, Red, Blue, so R parameter will be green, and U parameter will be blue.
On displays that support NeoPixel RGB backlights, set these with M150.
M918 P2 E2 F2000000 ; configure direct-connect display
M150 X2 R255 U255 B255 P127 S1 F1 ; display LED
M150 X2 R0 U0 B0 P0 S1 F1 ; left encoder LED off
M150 X2 R0 U0 B0 P0 S1 F0 ; right encoder LED off
M918 P2 E-4 C100 R3
M150 X2 R255 U0 B0 P255 S3 F0 ; GRB LED so this shows green
To configure this type of display in RepRapFirmware, use the M918 command with display type parameter P1, e.g.:
M918 P1 E4 F2000000
(Instructions from https://teamgloomy.github.io/tft.html, thanks!)
Recent versions of the standard bigtreetech TFT firmware have built in support for RepRapFirmware. The pre-built images have this enabled by default.
As of September 2023, BTT firmware still MOSTLY works with RRF. Heating, movement, monitoring prints etc. work. However, accessing the Duet filesystem does not. There may be other quirks that break RRF support as the firmware develops. Duet3D is not responsible for the BigTreeTech firmware. Please contact BTT to get these fixed. See this thread on the forum for more information.
Use the pins +5V, GND, IO_0_OUT and IO_0_IN on the IO_0 header (Duet 3), or +5V, GND, TX and RX on the PanelDue header (Duet 2). These should be connected to +5V, GND, TX and RX on the TFT, making sure that TX and RX are swapped.
| BTT display | Duet 3 IO_0 header | Duet 2 PanelDue header |
| +5V | +5V | +5V |
| GND | GND | GND |
| TX | IO_0_IN | URXD0 |
| RX | IO_0_OUT | UTXD0 |
There is now an RRF config.ini (on the SD card root). It needs to be renamed from config_rrf.ini to config.ini (replacing the original one for Marlin) for flashing of the firmware.
Add one of the following lines to your config.g to enable the screen
M575 P2 S1 B57600 ; RRF 3.7 and later on Duet 3
M575 P1 S1 B57600 ; RRF 3.6 and earlier
