A rotary delta printer has three radial upper arms that rotate in a vertical plane about bearings at their inner ends. These joints are driven by motors, which control the angle of each arm above or below the horizontal. The outer end or each arm is jointed to the top end of a pair of rods. The bottom ends of the rods are jointed to the effector.
Rotary Delta mechanisms are rarely used for 3D printing (unlike Linear Delta mechanisms), however they are commonly used in pick-and-place machines.
As for linear deltas, the firmware assumes that seen from above the motors and arms go anticlockwise in the order X, Y, Z; and that if the machine is viewed so that +X motion of the effector is from left to right, the Z joint is that the back of the machine.
Support for rotary deltas was added in RRF 2.02. RRF 3.3 added auto calibration (experimental) and the use of segmented moves for Z.
To select rotary delta mode and configure the machine parameters use the M669 command in config.g:
M669 K10 Uxx:yy:zz Lxx:yy:zz Rrr Aaa:bb Hxx:yy:zz Xxx Yyy Zzz
The parameters have the following meanings:
As for linear deltas, the M666 command may be used to trim the homing switch positions:
M666 Xxx Yxx Zzz
The X, Y and Z parameters in this case are the angles (in degrees) that must be added to the nominal upper angle at which the homing switches trigger to get the actual trigger angles.
The X, Y and Z values in the M92 command must be the number of microsteps per degree of arm rotation. This is calculated as the microstepping selected (default 16) divided by the motor step angle (normally 1.8 or 0.9 degrees), and multiplied by the ratio of any gearing between the stepper motor shaft and the joint.
The M208 Z parameters should be set to the maximum and minimum permitted Z coordinates.
Test the three arm motors individually by putting the printer in relative mode (G91 command) and then using the G1 command with H2 parameter (S2 in RRF 2.01 and earlier). For example, sending G1 H2 X5 F60 should move the X arm up 5 degrees at 1 degree per second (60 degrees per minute), and sending G1 H2 X-5 F60 should move the X arm down 5 degrees. Similarly for Y and Z if you replace X by Y or Z in the above commands. If a motor moves the wrong way, you can reverse it by changing the corresponding M569 command in config.g. For example, if the X motor moves the wrong way, change M569 P0 S1 to M569 P0 S0 or vice versa.
Use the M119 command to read the state of the endstop switches. When the X arm is in its maximum up position so that it is pressing against the endstop switch, it should report "X: at max stop". At any other position it should report "X: not stopped". Similarly for Y and Z.
Set up your homedelta.g file as you would for a linear delta (see Configuring RepRapFirmware for a Linear Delta Printer) except that in all G1 H1 and G1 H2 commands, the F parameter should be the speed in degrees per second. Then test the Home All function. The arms should move to the maximum position until they all trigger the switches, then back off a little, then move more slowly to the maximum position. Finally the effector will drop 5mm and be centred.
After homing the printer, send G90 then G1 H2 X0 Y0 Z0 F60. It should move all 3 arms to the horizontal position (at 1deg/second). The next step is to adjust the endstop offsets so that that the arms are all exactly horizontal after sending this command. So check them, for example using a spirit level. Note: "horizontal" here means that a line between the rotation centres of the joints at either end of the arm is horizontal.
To get an arm to be horizontal, you need to adjust what the firmware thinks the arm angles are when the endstop is triggered. The arm angles are given by the second number in the A parameter of the M669 command. For example, you may have used A-25:30 meaning that the minimum arm angle is 25 degrees below the horizontal, and the maximum arm angle (which is the angle at which the endstop triggers) is 30 degrees above the horizontal. If after sending G1 H2 X0 Y0 Z0 F60 you find all arms are below the horizontal, subtract the angular error from the second A value. For example, using the above figures, if the command places the arms 2 degrees below the horizontal then change A-25:30 to A-25:28. Similarly, if the command leaves the arms above the horizontal, increase the second A parameter by the angular error.
You can fine-tune individual arms using the M666 command. When used in config.g, this command must come after the M679 command. For example, M666 X0.1 Y0.2 Z-0.3 will change the position (after homing and sending G1 H2 X0 Y0 Z0 F60) such that the X arm is 0.1 degree lower, Y is 0.2 degree lower, and Z is 0.3 degree higher.
After making any changes to the M679 or M666 values, home the printer and send G1 H2 X0 Y0 Z0 F60 again to see the effect of the changes.
You can now try out some real moves to make sure that everything is functioning correctly.
If you find that the Z=0 position is too high, increase the H parameter in the M669 command by the amount of the error. If it is too low, reduce the H parameter.
Similar to auto-calibration on a linear delta, auto-calibration on rotary delta is supported from RRF 3.3b2. You will need a Z probe; follow the auto calibration advice on the linear delta page: Calibrating a delta printer but note the following differences:
The bed.g file defines the points that will be probed, and the S parameter in the last G30 command defines number of factors that will be calibrated. RepRapFirmware supports the following calibration schemes:
