For a general guide to configuring RepRapFirmware, see Configuring RepRapFirmware for a Cartesian printer. Only the differences for Hangprinters are described here.
RepRapFirmware is configured at run-time by means of files in the /sys folder of the on-board SD card or attached Single Board Computer (SBC). You do not have to recompile RepRapFirmware to configure it, so if you wish to update the firmware on your Duet or other compatible electronics board, you can download a ready-built binary.
The easiest way to generate these files is using the RepRapFirmware configuration tool. This tool does not currently support Hangprinters, so you will need to edit the generated config.g file by hand to change the kinematics type to Hangprinter.
Hangprinter kinematics are supported in RepRapFirmware 1.20 and later. Spool build-up compensation was added in RepRapFirmware 3.3, and there are various improvements in 3.4 and 3.5. From RRF 3.5, Hangprinter kinematics are no longer supported in the default firmware binary for Duet 2 WiFi/Ethernet, due to memory limitations.
The Hangprinter architecture in its current form was designed and developed by Torbjørn Ludvigsen, his github repository has a large amount of information and is a great place to start to understand the Hangprinter in general.
In brief, a Hangprinter has four positioning motors (A, B, C and D) mounted either on a large effector or mounted at the anchor points. Each motor drives a spool which draws in or lets out 2 or 3 lines that pass through eyelets and then go to fixed anchor points. The D spool has 3 lines connected to anchor points in the ceiling. The A, B and C spools each have 2 lines connected to anchor points on the floor. The Hangprinter is under very active development so this may not match the current state of the art.
Additional info can be found at Hangprinter.org or at the Hangprinter RepRap Forum, or this thread in the Duet3D forum.
The Hangprinter kinematics can be used for other types of cable-driven machines, for example polargraph drawing machines. See this thread in the Duet3D forum for an example.
To tell RepRapFirmware that your printer is a Hangprinter and to define its parameters, use M669. Put command M669 K6 Axx:yy:zz B xx:yy:zz Cxx:yy:xx Dzz Prr in your sys/config.g file. The parameters are:
Hangprinter kinematics assume a central XYZ origin. The XYZ coordinates in the ABCD parameters are the offset of each anchor from the line entry point on the effector, ie not the offset of the anchor from the nozzle.
Image by Torbjørn Ludvigsen, from reprap.org wiki, click image above for original.
You will need to create an invisible U axis to handle the D spool motor with M584, like this:
M584 X0 Y1 Z2 E3 U4 P3
In this example, the ABCD spool motors are connected to the X Y Z and E1 motor connectors respectively (Duet 2), and the extruder motor is connected to the E0 motor connector. The P3 parameter restricts the number of visible axes to 3.
The M666 parameters are used to configure the buildup compensation for the Hangprinter. Each parameter adjusts how the firmware compensates for the line buildup on the spools during operation.
ODrive motor controllers are connected to CAN0 of the Duet 3 MB6HC or MB6XD. From RRF 3.7.1, CAN0 is a CAN-FD expansion bus by default, so add M953 P0 C1 near the start of config.g to make it a classic CAN bus for the ODrives.
In the M92 command, the XYZU parameters are the steps per mm of line extension or retraction by the A, B, C and D spools.
The Z movement limits should be set in M208 commands as usual.
Here is an extract from a sample config.g file (Duet 2, RRF 3.x):
** Axis and motor configuration**
M569 P0 S1 ; drive 0 (X motor output aka A) goes forwards
M569 P1 S1 ; drive 1 (Y motor output aka B) goes forwards
M569 P2 S1 ; drive 2 (Z motor output aka C) goes forwards
M569 P3 S1 ; drive 3 (extruder) goes forwards
M569 P4 S1 ; drive 4 (E1 motor output aka U aka D) goes forwards
M584 X0 Y1 Z2 E3 U4 ; create U axis for the D motor, attached to the E1 motor connector
M669 K6 A0.0:-2163.0:-75.5 B-1841.0:741.0:-75.5 C1639.0:1404.0:-75.5 D3250.5 P1500 ; set Hangprinter kinematics parameters
M92 X101.86 Y101.86 Z101.85 U101.86 ; set steps/mm for each spool - SEE NOTES BELOW
M203 X6000 Y6000 Z6000 U6000 E3600 ; maximum linear speeds mm/minute
M906 X1000 Y1000 Y1000 U1000 E1000 ; set motor currents (mA)
M208 S0 Z1500 ; maximum height 1500mm
M208 S1 Z-5 ; minimum height -5mm
Hangprinters do not have homing switches. To home your Hangprinter, we suggest the following:
G1 H2 U-100 F1000.You may wish to create a homeall.g file that does some of these steps.
Note: the auto-calibration described below calibrates bed tilt or bed shape, not anchor positions and spool buildup.
You can use the following types of auto calibration:
You must use at least as many probe points as calibration factors you want to use. More probe points is better and will give you an indication of the height errors after calibration.
Auto calibration is performed by sending command G32 (which is the same command used to do auto bed compensation on a Cartesian printer). This command runs macro file sys/bed.g, so all the work is done there. Here is a sample bed.g file:
M561 ; clear any bed transform, otherwise homing may be at the wrong height
M401 ; deploy the Z probe
G30 P0 X0 Y0 Z-99999 ; dummy probe, needed only if your Z probe gives less accurate results the first time it is used after deployment
** Probe the bed and do 6-factor auto calibration**
G30 P0 X0 Y-1050 Z-99999 ; towards A anchor
G30 P1 X-460 Y-340 Z-99999 ; between A and B anchors
G30 P2 X-920 Y370 Z-99999 ; towards B anchor
G30 P3 X-50 Y535 Z-99999 ; between B and C anchors
G30 P4 X820 Y700 Z-99999 ; towards C anchor
G30 P5 X420 Y-175 Z-99999 ; between C and A anchors
G30 P6 X0 Y-525 Z-99999 ; halfway to A anchor
G30 P7 X-460 Y185 Z-99999 ; halfway to B anchor
G30 P8 X410 Y350 Z-99999 ; halfway to C anchor
G30 P9 X0 Y0 Z-99999 S6 ; centre, and auto-calibrate 6 factors
M402 ; retract the Z probe
G1 X0 Y0 Z150 F15000 ; get the head out of the way of the bed
The probing is commanded by the G30 commands. You can have up to 32 probe points, numbered P0 to P31. The probe positions and order are not critical, but you should cover at least the centre and the extremities of the bed, both close to anchors and opposite the anchors, and some points in between the centre and the periphery. The XY coordinates are where the nozzle will be, so if the Z probe is displaced from the nozzle then you must allow for this.
This example uses ten points: six around the periphery, one at the centre, and three halfway between the centre and the periphery.
If your Z probe has different trigger heights at different XY positions, you can add an H parameter to each G30 command. This gives the value that must be added to the G31 Z parameter to get the actual trigger height at that point. Set the G31 Z parameter so that it is accurate when probing the centre of the bed, and use the H parameter to correct for different trigger heights at the other bed probe points. The H parameter is supported in firmware version 1.09e-dc42 and later.
The S parameter on the final G30 command is the number of factors to calibrate.
You can test the four motion motors individually by putting the printer in relative mode (G91 command) and then using the G1 command with H2 parameter. For example, after sending G91, sending G1 H2 X10 should increase the length of line between the A spool and the effector by 10mm; and sending G1 S2 U-20 should reduce the length of the line from the D spool by 20mm.
If a motor moves the wrong way, you can reverse it by changing the corresponding M569 command in config.g. For example, if the A spool motor moves the wrong way, change M569 P0 S1 to M569 P0 S0.
