The Duet 3 Roto Toolboard is designed to integrate easily with the E3D Revo Roto extruder and E3D Revo hotends, heaters and temperature sensors. The following connect using the E3D supplied connectors for easy wiring: extruder motor, a 2 or 3-wire heatsink fan, revo heater, thermistor, and secondary temperature sensor. This tool board also provides dedicated connectors for a Duet 3 scanning Z probe coil (supplied as standard) and a Revo Roto specific version of the Duet3D Magnetic Filament Monitor (additional cost option). It also supports a 2, 3 or 4-wire part cooling fan and provides 4 IO ports for endstops, other types of filament monitor and/or Z probe, and a Neopixel LED header.
This reduces the number of wires run to the print head to two power wires and a twisted pair for the CAN-FD bus.
| Processor | ATSAME51G19A |
| Processor features | 32-bit, 120MHz ARM Cortex M4F, 512KB Flash, 192KB RAM |
| Networking/Comms | CAN-FD interconnect to Duet 3 CAN-FD bus |
| On-board stepper driver | 1 x TMC2240 |
| Stepper driver features | Up to 1.6A1 peak current, microstep interpolation from any setting to x256, stall detection |
| High current outputs | 1 x 3.4A, VIN voltage only (80W at 24V) |
| Thermistor/PT1000 inputs | 3 x inputs, 2 optimised for 100K thermistors and PT1000 sensors, 1 used for the coil temperature on the SZP coil. |
| Medium current outputs | 1 x 4-pin (VIN voltage - designed for part cooling using 2, 3 or 4 pin fans) and 1 x 3-pin (5V compatible with the Roto heatsink cooling fan using 2 or 3 pin fans). Both are PWM-controlled output with tacho input |
| Inputs/Outputs | 3 x on-board I/O connectors for endstop, switches, filament monitor, Z probe. 1 x footprint for a switch or optical proximity sensor |
| Accelerometer | Integrated LIS2DW12 accelerometer |
| Inductive Sensor | Integrated LDC1612 inductive sensor for scanning Z probe |
| Power monitoring | VIN voltage reporting |
1 Maximum current is limited to 1.0A peak in firmware versions earlier than 3.6.0. The Revo Roto extruder motor should not be operated at more than 600mA.
| Stepper driver | Maximum 1.6A peak current, 1.13A RMS1 |
| OUT_1 maximum current | 3.4A |
| Input power voltage | 12V to 32V |
| Power input max current | 5A maximum) |
| Inputs/Outputs | IO_0, IO_1, IO_2 and IO_3 are 30V-tolerant |
| Fuses | None onboard. Use Duet 3 Tool Distribution Board (5A fitted), or if directly connected to a power supply use an inline fuse holder with 5A or lower fuse depending on required current draw. |
| 5V external load | 700mA maximum |
| 3.3V external load | 200mA maximum |
The mounting hole pattern is designed for the sized for the E3D Revo Roto, and it is sized to fit within the side dimensions of the Roto.
The STEP file is available on Github here.
Mount on the side of the E3D Roto with standoffs/spacers sufficient to ensure none of the components or connectors on the back of the board can touch the metal heatsink or motor of the E3D Revo Roto extruder. The E3D Revo Roto extruder can use either M3 through bolts or M4 self tapping plastic screws for mounting into the mounting holes. See E3D documentation for further information.
A simple spacer design is available here.
The mount for Roto and SZP coil board shown at the top of the page is available here. Note that you may need to adjust the mount to get the SZP coil at the correct height for your nozzle.
Duet 3 Roto Toolboard provides the following connectors:
| Connector | Label | Function |
| 1 x XT30 2+2 | VIN, GND, CAN_L,CAN_H | Two pins for main VIN and GND along with CAN pins. See CAN section below. |
| 4-pin Molex Microfit 2x2 | DRIVER_0 | Stepper motor connection |
| 3-pin JST PH | LED | Connection for Neopixel LEDs |
| 2-pin Molex Microfit | OUT_0 | High current output intended for an extruder heater, maximum current 3.4A, this is VIN voltage only. There is no flyback diode on this output, so if you connect a high-current inductive load, you must use an external flyback diode. |
| 2-pin Molex Microfit | TEMP_1 | Thermistor or PT1000 input |
| 2-pin Molex Microfit | TEMP_0 | Thermistor or PT1000 input |
| 4-pin 0.5mm pitch FFC | SZP | Connection for a Duet 3 Scanning Z Probe Coil |
| 3-pin JST PH | IO_2 | 3.3V, io2.in, GND, for endstop/ Z-probe/ Filament monitor. Input is 30V-tolerant |
| 3-pin Molex Microfit | OUT_2 | Medium current 5V output intended for, 5V Fan maximum current 0.6A, as part of the overall 5V power budget. Has optional Tacho input. Intended for the heatsink cooling fan on a Revo Roto There is no flyback diode on this output, so if you connect an inductive load, you must use an external flyback diode. |
| 4-pin JST PH | IO_0 | 5V, io0.in, GND, io0.out, for endstop/ Z-probe/ Filament monitor. Input is 30V-tolerant |
| 3-pin JST PH | IO_1 | 3.3V, io1.in, GND, for endstop/ Z-probe/ Filament monitor. Input is 30V-tolerant |
| 4-pin JST PH | OUT_1 | 4-wire fan output (also accepts a 2- or 3-wire fan) intended for use as the print cooling fan. 1A total max current at VIN voltage. This output is protected by a flyback diode. Note When using a 4-wire fan, the tacho reading is valid at all PWM settings. |
| 1 x 4-pin footprint | IO_3 | In version 1.0 this footprint intended for a ITR20001/T reflective optical sensor is reversed however the IO pin can be used for other purposes. Example use case is a tool docking confirmation switch. |
| 4-pin 0.5mm pitch FFC | I2C | For connecting the Revo Roto version of the Duet3D Magnetic Filament Monitor |
| VIN | Blue | Indicates presence of VIN power (VIN should be externally fused) |
| 3.3V | Green | Indicates presence of 3.3V power from on-board regulator |
| ACT / LED 1 | Green | Indicates activity on the CAN-FD bus |
| STATUS / LED 0 | Red | Status LED. See description below |
Status LED: In normal use, the red LED flashes slowly (approx 1Hz) in sync with the main board to indicate that it has CAN sync, or flashes continuously and rapidly to indicate that it doesn't. It also flashes startup error codes, for example if the bootloader doesn't find valid firmware on the board. For a list of these error codes see CAN_connection basics.
The Duet 3 series uses the pin name format "expansion-board-address.pin-name" to identify pins on expansion board, where expansion-board-address is the numeric CAN address of the board. A pin name that does not start with a sequence of decimal digits followed by a period, or that starts with "0." refers to a pin on the Duet 3 Mainboard.
| Function | Pin location | RRF3 Pin name | Notes |
| Outputs | OUT_0 | out0 | VIN voltage |
| OUT_1 | out1 | VIN voltage | |
| out1.tach | |||
| OUT_2 | out2 | 5V | |
| out2.tach | |||
| Inputs/Outputs | IO_0 | io0.out | 5V power , 3.3V logic on io0.out |
| io0.in | 30V tolerant | ||
| IO_1 | io1.in | 30V tolerant | |
| IO_2 | io2.in | 30V tolerant | |
| IO_3 | io3.in | 30V tolerant. | |
| TEMP_0 | temp0 | ||
| TEMP_1 | temp1 | ||
| TEMP_2 | temp2 | Scanning Z Probe coil thermistor | |
| LED | led |
OUT_0, OUT_1 and OUT_2 are PWM-capable.
| IO # | UART? | Analog in? | PWM out? | Notes |
| IO_0 | Yes | Yes | Yes | Note: RepRapFirmware does not currently support UART or I2C on Duet 3 expansion/tool boards. |
| IO_1 | No | No | No | Input only, no output pin |
| IO_2 | No | No | No | Input only, no output pin |
| IO_3 | No | No | No | Input only, no output pin |
Supply between 12V and 32V to the appropriate pins of the XT30 2+2 power connector on the Toolboard through a fuse and observing the correct polarity. Inline blade fuse holders are readily available, pick the lowest rated fuse appropriate for your heater and motor current draw.
OUT ports on the mainboard should NOT be used to switch power to expansion or tool boards directly. See the note at the end of the 'inrush current' section at the link above.
See also CAN Connection Basics.
It is possible to connect a Roto Toolboard directly to the Duet 3 Mainboard 6HC, 6XD, Duet 3 Mini 5+, or daisy chain it with other toolboards or any Duet 3 Expansion board.
The XT30(2+2) pre-wired cables supplied with the boards have different wire colours depending on the wiring batch.
| CAN | Prototpyes and initial V1.0 | Later V1.0 | Moulded connector | Moulded connector (first version) |
| CAN H | Blue | Yellow | Yellow | Yellow |
| CAN L | White | White | White | Green |
Connect the RJ11 socket on the Duet 3 Mainboard 6HC, 6XD or Expansion board, pins 3 and 4 (the middle 2 pins) of the RJ11 connector to pins 4 and 3 of the Toolboard, making sure you get them the right way round i.e. CAN1_H in the Duet to CAN_H on the Toolboard. Don't connect anything to pins 2 and 5 of the RJ11 connector on the Duet.
On the Duet 3 Mini 5+ connect the CAN_FD socket to the 2 CAN pins on the Toolboard, and terminate the other 2 CAN pins.
You can use the Roto tool board with the existing Tool Distribution Board (TDB) like this:
If the cable length from the TDB to the Roto Tool Board is no more than 1m:
If it's more than 1m:
Multiple Duet 3 Roto toolboards can be connected by daisy chaining the CAN bus connection.
Note only the last CAN-FD device on the bus should have the termination resistor fitted.
Fit the 2.0mm pitch jumper on the CAN Termination resistor jumper pins if the Roto Toolboard is to be the last device on the CAN_FD bus.
Add the following to your sys/config.g file
It is recommended to add the following to config.g, before any commands that reference any CAN bus connected expansion boards, eg close to the start of config.g
G4 S2 ; wait for expansion boards to start
The default CAN address is 121. Changing the CAN address is only necessary if you have another CAN-connected boards with the same CAN address, eg another Duet 3 Toolboard.
All boards in the system must have different CAN addresses. Toolboards are shipped set to a default CAN address of 121. Therefore, if you have more than one Toolboard, only one of them must be powered up and connected to the CAN bus until the address is changed. So disconnect power to all but one of them (you can leave the CAN bus connected if it's easier).
M115 B# to verify that the main board can communicate with the Toolboard, where # is the original CAN address (normally 121)M952 B# A## where ## is the new address you want to use. We suggest you use addresses starting at 20 for Toolboards. So for the first Toolboard, if your new CAN board was at address 121, send M952 B121 A20.M999 B121. This will cause the Toolboard to restart with the new address.M122 B20 (or whatever address you chose) to verify that you can communicate with the Toolboard at its new addressCheck that you can communicate with the Roto toolboard, by sending
M115 B121
Result should be something like
Duet TOOL1RR firmware version 3.7.0 (2026-10-08 12:18:44)
For a full report, send
M122 B121
The status of the accelerometer and Inductive probe is listed at the end of the report.
In normal use, the red LED flashes slowly in sync with the main board to indicate that it has CAN sync, or flashes continuously and rapidly to indicate that it doesn't. It also flashes startup error codes, for example if the bootloader doesn't find valid firmware on the board.
The board will do a factory reset if you power it up with a 2.0mm jumper fitted to the CAN reset jumper pins. The CAN address will be reset to the default (121), the CAN bus timing will also be reset to default (1Mbps), and the bootloader will request a firmware update.
The Roto Toolboard needs RRF v3.5 or later, and the same firmware version must also be running on the Duet 3 mainboard.
Usually, if you update the firmware using the .zip package of the latest release, connected CAN boards will be updated to the same release.
To check versions are the same:
M115 and M115 B# (where # is the Roto Toolboard CAN address, usually 121) to report the firmware version of the mainboard and the Roto Toolboard.M997 B# command, where # is the CAN address of the board.Factory resetting the board using the CAN reset jumper will cause the bootloader to erase the current firmware, reset the CAN address to the default value of 121, and request the firmware file from the mainboard.
Updating the bootloader is rarely necessary.
Duet 3 expansion boards and tool boards have a bootstrap loader written to the start of flash so that they can load firmware from the main board via CAN. This bootloader may occasionally need to be updated in order to support new features. See Updating the bootloader on Duet 3 expansion and tool boards.
The Duet 3 Roto Toolboard integrates the same inductive sensing chip as the Duet 3 Scanning Z Probe. It allows for a point mesh of the bed to be built up quickly as no movement in Z is required to read the bed distance, and individual readings happen very quickly.
Here is an example point map form the SZP on a Duet 3 Mainboard 6HC
Example mesh of 792 points that took ~20 seconds to produce.
The SZP is most effective in the range when the bottom of the SZP coil is between 2 to 6mm from the bed; all SZP probing and scanning should be done within this range. Probe resolution drops above and below this range. Ideally, the bottom of the SZP coil should be around 2.5mm to 3mm above the tip of the nozzle. This allows the SZP to act as a Z probe, for setting Z datum, and function as a bed mesh scanner.
However, there are some caveats if you have a bed that has distortion, as the nozzle may hit the bed surface during scanning. You may need to mount the SZP coil closer to the bed, so the nozzle is further from the bed during scanning. This may cause the SZP to be ineffective for setting Z datum, and require the use of another probe or other way of setting Z datum.
See Scanning Z Probe calibration for full instructions on mounting, configuring, calibration and usage.
Use a 4-way, 0.5mm pitch FFC with contacts on opposite sides. Duet3D supplies 50mm and 150mm cables. Longer cables can be used, but the capacitance of the cable is part of the coil's tuned circuit, so any change in that capacitance (for example when the cable moves) appears as a change in measured height. A longer cable also picks up more interference. To keep readings stable:
After changing the cable, recalibrate the drive current and the height vs reading.
Add the following to your config.g:
; Scanning Z probe
M558 K1 P11 C"121.i2c.ldc1612" F36000 T36000
M308 A"SZP coil" S10 Y"thermistor" P"121.temp2" ; thermistor on coil
For SZP calibration and usage, see Scanning Z Probe calibration
M955 P0 C"121.i2c.lis" I10 ; Add accelerometer 0 on Roto with CAN address 121 and specify orientation
In RRF 3.6 and earlier, use M955 P121.0 I10 instead.
See M955 for how to setup and configure the accelerometer.
The Duet 3 Roto toolboard has an XYZ arrow to aid orientation of the accelerometer. The Z axis is in the direction of the top face of the board/chip. The default alignment is to align the axes on the board with the axes of your machine, but it may not be possible, so this is configurable in M955.
For an overview of using accelerometers to capture data on axis movement see: Connecting an accelerometer
The Toolboard supports probe type 8 (unfiltered switch) and 9 (BL Touch), and in RRF 3.7 and later type 1 (analog). To connect a BL Touch, see table below.
| Toolboard IO_0 connector pin | BLTouch pin | Colour |
| io0_out | Control | Orange |
| GND | GND | Black + Brown |
| io0_in | OUT | White |
| 5V_EXT | +5V | Red |
For filament monitoring, we recommend using the Duet3D Roto Filament Monitor, which is designed specifically to work with the Roto Toolboard and extruder.
It is also still possible to use the Duet3D Magnetic Filament Monitor
Connector IO_1 or IO2 provides a 3.3V supply and 3.3V input signal level, suitable for a Duet3D Rotating Magnet filament monitor.
See Connecting and configuring a filament runout sensor
