The Duet 3 Mini 5+ balances value and performance, focused on small and medium size machines that do not need the high power output of the Duet 3 Mainboard 6HC. It provides 5 on board drivers and the normal complement of heaters, fans, IO, LCD etc. There are Wifi and Ethernet variants, with the option of using an SBC (Single Board Computer, e.g. Raspberry Pi) for control in the same manner as other Duet 3 mainboards. It has a header for a two driver expansion board and a CAN-FD port for connecting Duet 3 expansion and tool boards.
Except where otherwise stated, the following applies to both the WiFi and Ethernet versions.
The main hardware features of the Duet 3 Mini 5+ are listed below.
| HARDWARE SPECIFICATION | ||
| Duet 3 Mini 5+ WiFi | Duet 3 Mini 5+ Ethernet | |
| Processor | ATSAME54P20A | |
| Processor features | 32-bit, 120MHz ARM Cortex M4F, 1Mb flash, 256Kb RAM, hardware floating point (single precision), DMA, 4Kb cache | |
| Networking/Comms | 2.4GHz WiFi; USB port; up to two serial ports; CAN-FD bus | 10BaseT/100BaseTX Ethernet; USB port; up to two serial ports; CAN-FD bus |
| On-board stepper drivers | 5 x TMC2209 | |
| Stepper driver features | Up to 2.0A peak current, microstep interpolation from any setting to x256, stall detection, stealthChop2 | |
| High current outputs | 1 x 15A, 2 x 5A each | |
| Medium current outputs | 4 x PWM-controlled outputs, of which 2 support tacho input. Voltage selectable between VIN and 12V in 2 banks | |
| Thermistor/PT1000 inputs | 3 x inputs, optimised for 100K thermistors and PT1000 sensors | |
| Inputs/Outputs | 5 x on-board I/O connectors plus 2 x input-only connectors for endstop, filament monitor, Z probe, hobby servo or PanelDue connection. Inputs are 30V-tolerant. Also one output with 5V signal level for hobby servo, laser control or VFD. Two of the I/O connectors have serial UART support. | |
| Power monitoring | VIN voltage monitoring allows for the state to be saved on power failure. | |
| SD card interface | On-board high speed SD card socket. | |
| EXPANSION | ||
| Support for attached Raspberry Pi or other Single Board Computer (SBC) | Yes | |
| External stepper driver support | 2 x external stepper drivers from stepper driver expansion connector. Multiple expansion via the CAN-FD bus. | |
| Stepper driver expansion | 2 x additional TMC2209 stepper drivers using a Duet 3 Expansion Mini 2+. Further expansion via CAN-FD bus | |
| PT100, thermocouple and ADC daughterboard support | Supports 1 x daughterboard on board. More via CAN-FD-connected expansion boards. | |
| LCD support | PanelDue colour touch screen, mini 12864 mono graphics display using ST7567 controller (3.3V signal levels) | |
| LED strip support | RGB Neopixel (max. 60 LEDs, external 5V power required) | |
| Other expansion | Via I/O ports and CAN-FD bus | |
| Stepper drivers | Up to 2.0A peak current |
| High current outputs | OUT0 up to 15A. OUT1/2 up to 5A each |
| Medium current outputs | Up to 2A per output when powered from VIN. Up to 800mA total when powered from 12V |
| Input power voltage | 11V to 25V |
| Input connector rated current | 25A maximum, or fused limit (whichever is lower) |
| Inputs/Outputs | Inputs are 30V-tolerant |
| Fuses | 10A for V_FUSED, 15A for OUT0 (e.g. for a heated bed). |
| 5V current limit | 1A total on 5V and 3.3v, including the internal current consumption (around 200-300mA), any PanelDue or other display, and any endstops/Z probes that draw significant power. |
| 12V current limit | 800mA total (only used for outputs OUT_3 thru OUT_6, when selected) |
See the Hardware overview page for a feature comparison table between different versions of the Duet.
The form factor of the Duet 3 Mini 5+ is the same as the Duet 2 WiFi/Ethernet and can be mounted in much the same way, though the driver connectors are flipped sides compared to the Duet 2 WiFi/Ethernet.
In many applications passive cooling will be sufficient, especially if the board is mounted vertically in a well ventilated position. If active cooling is needed then a fan blowing across the back of the board along the line of the stepper drivers is recommended.
The stepper drivers' heatsinks are connected to the PCB and the majority of the heat is dissipated via the PCB so heatsinks on the stepper driver chips are largely ineffective.
The errata document for the SAME54P20A chip used in the Duet 3 Mini 5+ says the nchip temperature sensor does not work properly. However, it has been enabled in RRF 3.3 and later as an experiment, and does appear to give useful readings on the samples tested.
The TMC2209 driver sensors do work for fan control, but only return flags of warning and overtemp,
The STEP files for both boards are available on Github here.
Note: The jumper for I03.in on v1.03 boards provides no functionality because I2C is not supported on those pins, it is removed in v1.04.
Duet 3 Mini 5+ v0.4 wiring diagram
| Duet 3 Mini 5+ Connectors | ||
| 1 x 4-way barrier strip | POWER IN, GND, VIN | Two pins for main VIN and GND |
| OUT_0, V_OUT_0_OUT, OUT_0_NEG | Two pins for positive and negative OUT_0 terminals. OUT_0 is intended to drive a bed heater or other high current resistive load. If you connect an inductive load to this output, you must use a suitably rated external flyback diode. The ground side of OUT_0 is switched by the mosfet and the positive side is protected by a 15A fuse. | |
| 2 x 2-pin JST VH connectors | OUT_1, OUT_2 | Intended for extruder heaters or similar medium/high current resistive loads. The out1 and out2 pins are PWM switched GND, the V_FUSED pins are fused input voltage. Flyback diodes are built-in to these outputs. Maximum recommended current 6A each. |
| 2 x 4-pin KK connectors | OUT_3, OUT_4 | Intended for PWM-controllable fans or other medium/low current loads. Flyback diodes are built-in to these outputs. The connector fits a standard PC-type 4-pin PWM fan. Alternatively, a 2-pin fan may be connected between the V_OULC1+ pin (+ve) and the OUT_n_NEG pin (-ve). |
| Note: OUT_3 and OUT_4 are protected by a flyback diode to V_FUSED. This does not provide protection if driving these outputs from a higher voltage than V_FUSED | ||
| 1 x 3-pin Jumper | OUT_3&4 Select V | The positive supply to the above connectors is the centre pin of the 3-pin jumper block. A jumper in the "left" position will power them from the fused VIN supply (max 2A each ). A jumper in the "right" position will power them from the onboard 12V regulator (subject to overall 12V supply current see note 1 below). |
| 2 x 2-pin KK connectors | OUT_5, OUT_6 | These are intended for PWM-controllable fans or other medium/low current loads. Flyback diodes are built-in to these outputs. Note out_6 PWM pin is shared with LASER/VFD |
| Note: OUT_5 and OUT_6 are protected by a flyback diode to V_FUSED. This does not provide protection if driving these outputs from a higher voltage than V_FUSED | ||
| 1 x 3-pin Jumper | OUT_5&6 Select V | The positive supply to the above connectors is the centre pin of the 3-pin jumper block. A jumper in the "left" position will power them from the fused VIN supply (max 2A each ). A jumper in the "right" position will power them from the onboard 12V regulator (subject to overall 12V supply current see note 1 below). |
| 5 x 4-pin KK connectors | DRIVER_0, DRIVER_1, DRIVER_2, DRIVER_3, DRIVER_4 | Stepper motor connections, See "Connecting Stepper Motors" section below. |
| 1 x 16-pin socket strip | EXTERNAL DRIVERS | Step, Direction, Enable, Diag and UART connections for DRIVER_5 and DRIVER_6, along with fused VIN, ground, 3.3V and 5V. Designed for a Mini 2+ expansion board to plug directly in. Step, direction and enable can also be used with other external drivers (3.3V signal level). |
| 1 x 2x5 IDC connector | PanelDue_SD | Connects the PanelDue UART and shared SPI bus for external SD card. Powered from 5V supply (see note 2). Note shared with io0.in and io0.out pins on the IO_0 header. |
| 1 x 3-pin KK connectors | LASER/VFD | 5V buffered output shared with out6, along with 5V and ground supply (see note 2 below). Provides a 5V PWM signal to drive hobby servos, and PWM->analog controls for VFDs or Lasers. Note out6 PWM pin is shared with OUT_6 |
| 1 x 2-pin KK connectors | 12V | Always on 12V supply (see note 1 below) |
| Network | Ethernet | 1 x RJ45 100BaseT Port. non MDIX connect to an Ethernet switch, hub or MDIX enabled laptop port. If connecting to a non MDIX enabled port use a crossover cable. Orange LED on Ethernet port indicates Ethernet enabled, green LED indicates network activity |
| Wifi | U.FL/IPEX push on connector for external antenna. Note this connector is delicate, take care when plugging and unplugging. "LED ESP": green LED indicates Wifi connection status | |
| Reset | Single push to reset the board. Double push to put the board into UF2 bootloader upload mode. See User manual: Updating firmware - Duet 3 Mini 5+ via USB | |
| 1 x JST ZH 6-pin connectors | SWD | Connection for an SWD programming device such as an Atmel-ICE |
| 1 x 2-pin KK connectors | CAN | CAN-FD Bus connection for Duet 3 CAN-FD expansion boards. |
| 5 x 5-pin KK connectors | IO_0, IO_1, IO_2, IO_3, IO_4 | These are for endstop switches, Z probes, filament monitors and other low-voltage I/O functions. Each connector provides both 3.3V and 5V power. The inputs will tolerate up to 30V with 10K series resistors (but see below for bypass option). The outputs are 3.3V signal levels with 470R series resistors. IO_1,2,3 are PWM capable. IO_0 and IO_1 can optionally be configured as serial ports instead. |
| 1 x 2-pin Jumpers 10K->470R bypass | IO2. in | v1.01 and later only. Fit the IO2. in jumper to bypass the 10K resistor on io2. in with a 470R resistor. The IO2. in jumper must be fitted to use IO_2 for I2C, see I2C. Note: The IO3. in jumper has no function, because I2C is not supported on IO_3. It was removed in v1.04 |
| 2 x 3-pin KK connectors | IO_5, IO_6 | Input only IO connections that will tolerate up to 30V with 10K series resistors. Perfect for simple endstop switches. |
| 3 x 2-pin KK connectors | TEMP_0, TEMP_1, TEMP_2 | Connections for thermistor or PT1000 sensors. |
| 1 x 2x13 IDC connector | SBC | Connections to a Single Board Computer (SBC) such as a Raspberry Pi. |
| 1 x 2x5 IDC connector | SPI DB | (Connector named TEMPDB before v1.03) For connecting a PT100, thermocouple, ADC or Duet3D Accelerometer interface board. Note on v1.02 and earlier boards cannot be stacked so only 1 board at a time is supported. |
| 2 x 2-pin Jumper2 | SPI3_SELECT SPI4_SELECT |
Version 1.03 and later: only. Route the spi.cs3 and spi.cs4 signals to the SPI DB connector instead of the 12864 display EXT1 connector |
| 1 x 3-pin Jumper | 5V_SELECT | v0.5-v1.02 Source of optional External 5V input, see note 2 below |
| 2 x 3-pin Jumpers | 5V_SELECT | Version 1.03 and later: Source of optional External 5V input, see note 2 below |
| 1 x 2-pin Jumper | Int_5V_Disable | Connect a jumper across this to disable the internal 5V regulator, see note 2 below |
| 2 x 2x5 IDCs | 12864_EXP1, 12864_EXP2 | Headers for connecting a 12864 display using a ST7567 controller, see "Connecting a 12864 display" below. |
| 1 x 3-pin KK connector | NP_LED | This is to connect and power NeoPixel LED strips (DotStar LED strips are not supported) . Connect the DO pin to Neopixel DI. External 5V must be supplied to the "EXT 5V" header to power the NeoPixel array; they cannot be powered from the onboard regulator. |
| 1 x 3-pin KK connector | EXT 5V | Input for External 5V supply, see Note 2 below. There is a buffered 5V "pson" pin which can be used to switch an external supply, note it is shared with io4.out |
| ACT | Green | Indicates activity on the CAN-FD bus |
| STATUS | Red | See description below |
| V_FUSED | Blue | Indicates fused VIN supply present |
| 12V+ | Amber | Indicates indicates on-board 12V regulator operating |
| 5V+ | Red | Indicates indicates 5V supply present |
| 3.3V+ | Green | Indicates on-board 3.3V regulator operating |
| ESP | Green | WiFi version only. Indicates WiFi activity; flashing for searching/connecting, on for connected. |
| OUT_0 | Red | Next to the OUT 0 connector, indicates when on |
| OUT_1 | Red | Next to the OUT 1 connector, indicates when on |
| OUT_2 | Red | Next to the OUT 2 connector, indicates when on |
The red LED next to the Reset button is labelled "STATUS". It indicates the state of the board, as follows.
| LED | Meaning |
| Flashing steadily, about half a second off and half a second on | Normal operation, RepRapFirmware is running |
| Flashing three times, then off for a while | Firmware CRC check failed |
| Fading from bright to dim and then back again | USB bootloader activated |
RepRapFirmware 3 uses pin names for user-accessible pins, rather than pin numbers, to communicate with individual pins on the PCB. In RRF 3 no user-accessible pins are defined at startup by default. Pins can be defined for use by a number of Gcode commands, e.g. M574, M558, M950.
The Duet 3 series uses the pin name format "expansion-board-address.pin-name" to identify pins on expansion board, where expansion-board-address is the numeric CAN address of the board. A pin name that does not start with a sequence of decimal digits followed by a period, or that starts with "0." refers to a pin on the Duet 3 Mini 5+.
| Pin location | RRF3 Pin name | Notes |
| OUT_0 | out0 | High current output, bed heater |
| OUT_1 | out1 | Medium current outputs, hot ends |
| OUT_2 | out2 | |
| Outputs (4-pin) | ||
| OUT_3 | out3 | 4-wire fans with tacho |
| out3.tach | ||
| OUT_4 | out4 | |
| out4.tach | ||
| Outputs (2-pin) | ||
| OUT_5 | out5 | |
| OUT_6 | out6, laser, vfd | Pin shared with OUT 6 and LASER/VFD connectors |
| TEMP_0 | temp0 | |
| TEMP_1 | temp1 | |
| TEMP_2 | temp2 | |
| Inputs/Output | ||
| IO_0 | io0.in | PanelDue, endstops, Z probes, filament monitors etc. It shares io0.out and io0.in pins with the PanelDue_SD connector. |
| io0.out | ||
| IO_1 | io1.in | Endstops, Z probes, filament monitors etc. |
| io1.out | ||
| IO_2 | io2.in | Endstops, Z probes, filament monitors etc. On v1.01 and later boards, IO_2 can also be used for I2C, see I2C. |
| io2.out | ||
| IO_3 | io3.in | Endstops, Z probes, filament monitors etc. |
| io3.out, lcd.np (12864 neopixel pin) | ||
| IO_4 | io4.in | |
| io4.out, pson | ||
| IO_5 | io5.in | Input only |
| IO_6 | io6.in | |
| SPI DB | spi.cs1 | (Connector named TEMPDB before v1.03) Thermocouple, PT100 or ADC daughterboard |
| spi.cs2 | ||
| spi.cs3 | v1.03 and later only, shared with lcd.cs3 Jumper selectable | |
| spi.cs4 | v1.03 and later only, shared with lcd.a0 Jumper selectable | |
| Miscellaneous | ||
| LASER/VFD | laser, vfd, out6 | Pin shared with OUT 6 and LASER/VFD connectors |
| EXT 5V | pson, io4.out | For controlling an external PSU or SSR, shared with io4.out |
| NEOPIXEL | led | For controlling Neopixel LEDs (firmware 3.5 and later only) |
| 12864_EXP1 | lcd.a0,exp1.7 | (RRF 3.5 and later only) Pin 7 of the EXP1 connector. Available for general output if no 12864 display is connected. Shared with spi.cs4 on SPI DB header on v1.03 and later. |
| enc.sw,exp1.9 | (RRF 3.5.0 and later) Pin 9 of the EXP1 connector. Available for general output if no 12864 display is connected. | |
| lcd.buzz,exp1.10 | (RRF 3.5.0 and later only) Pin 10 of the EXP1 connector. Available for general output including PWM if no 12864 display is connected. | |
| 12864_EXP2 | enc.b | (RRF 3.5 and later) Pin 6 of the EXP2 connector. Available for general input (max 3.3V) and output if no 12864 display is connected. There is no protection on this pin. |
| enc.a,exp2.8 | (RRF 3.5 and later) Pin 8 of the EXP2 connector. Available for general input (max 3.3V) and output if no 12864 display is connected. There is no protection on this pin. | |
OUT_0 to OUT_6 are all PWM-capable. OUT_6 is shared with LASER/VFD. See tables above for notes on voltage selection and current limits.
There are 7 IO headers on board. IO_0 to IO_4 have pins for input, output, 3.3V, 5V and Gnd supplied. IO_5 and IO_6 have an input, 3.3V and Gnd supplied. This enables support for a wide range of endstops, probes, filament monitors and future low bandwidth devices. RepRapFirmware 3 can be configured to map these ports to the appropriate functions as required.
Except as noted in the table below, an IO_x_IN pin can always be used to provide a digital input (e.g. for endstop inputs or filament monitors), and an IO_x_OUT pin can always be used to provide a digital output.
Additionally:
| IO # | UART? | Analog in? | PWM out? | Notes |
| 0 | yes | no | no | AUX0 port, can be used to connect a PanelDue. Configure using M575 P2 (RRF 3.7 and later) or M575 P1 (RRF 3.6 and earlier). It shares io0.out and io0.in pins with the PanelDue_SD connector. |
| 1 | yes | no | yes | AUX1 port. Configure using M575 P3 (RRF 3.7 and later) or M575 P2 (RRF 3.6 and earlier). |
| 2 | yes | no | yes | The standard firmware does not support this UART. Can be used for I2C, see I2C. |
| 3 | no | yes | yes | Shared with backlight control on 12864 displays having Neopixel backlights |
| 4 | no | no | no | IO4_OUT is shared with PSON output |
| 5 | no | no | n/a | 3-pin connector, input only |
| 6 | no | yes | n/a | 3-pin connector, input only |
RepRapFirmware 3.7.0 and later supports I2C on the Duet 3 Mini 5+. I2C can only be used with the M260 and M261 commands.
I2C can only be used on port IO_2, and the IO2.in bypass jumper must be fitted. This jumper is provided on v1.01 and later boards. I2C cannot be used on earlier boards, because they do not have this jumper.
The I2C SCL signal is on pin io2.in. The I2C SDA signal is on pin io2.out.
External pullup resistors must be connected between SCL and +3.3V, and between SDA and +3.3V. Some I2C device breakout boards include these resistors. If the resistors are not present, I2C does not work correctly.
Supply 12V-24V input power (11-25V absolute minimum/maximum) between the GND and VIN terminals.
VIN is split via two fuses:
V_FUSED is distributed across the board as follows:
If you use a relay to control VIN power to the board, i.e. the power supply is already switched on, and a relay is used to turn on power to the board, you should use an inrush current limiter wired in series with VIN. See the section on Inrush current here.
OUT ports on the board should NOT be used to switch power to other boards directly. See the note at the end of the 'inrush current' section at the link above.
12V_EXT: 800mA limit, Supplied to:
5V: Split up to 5V_EXT, 5V_INT. Those points can also be supplied by USB (i.e. VBUS) and from the 5V SELECT jumpers that allow selection from 5V_EXT_INPUT and 5V_SBC.
5V input can come from one of these sources:
5V: Split up to 5V_EXT, 5V_INT. Those points can also be supplied by USB (i.e. VBUS) and from the 5V_SELECT jumper that selects between 5V_EXT_INPUT and 5V_SBC.
3.3V: Internal 3.3V supply for onboard logic, Temperature Daughterboards and external drivers
The signal levels are mostly 3.3V. This means that LCD modules using a ST7920 display powered from 5V (e.g. the RepRapDiscount display) will not work reliably. Use a display with a ST7567 controller instead. The display we test with is the Fysetc Mini 12864 display version 2.1. You can connect this directly to the EXP1 and EXP2 connectors using the straight-through ribbon cables normally supplied with this display. Enable the display using these commands in config.g:
M918 P2 ; enable ST7567-based 12864 display
M950 E0 C"io3.out" T1 U3 ; create an RGB NeoPixel LED strip for the 3 LEDs
M150 E0 R255 U255 B255 S3 ; set all 3 LEDs to white
You can adjust the M150 command to change the backlight colours. Please note, interrupts are disabled for a short time while the backlight colours are changed, and printing will be paused during this time; therefore you should not change the backlight colours during a print.
Note: (v1.03 and later) the 12864 display cannot be used in conjunction with a second SPI DB as pins are shared.
A PanelDue can be connected to IO_0 using a 4-wire cable. See Connecting a PanelDue
Alternatively, it can be connected using a ribbon cable plugged into the socket labelled PanelDue_SD, which enables access to the PanelDue SD card socket. However, there are some caveats:
The Duet 3 Mini+ cannot power the Pi. You must power the Pi separately. The Raspberry Pi is sensitive to the input voltage, and many smartphone chargers or other USB power supplies cannot supply sufficient voltage. Therefore, we strongly recommend that you use the official Raspberry Pi PSU, or another PSU specifically designed to power a Raspberry Pi. If the red LED on the Pi is not continuously illuminated, the power supply is insufficient.
In other respects, SBC connection to the Duet and configuration is the same for the Duet 3 Mini as for the Duet 3 Mainboard 6HC. See SBC Setup for Duet 3.
When using an attached Raspberry Pi or other SBC, the WiFi or Ethernet interface on the Duet 3 Mini+ is disabled.
See Connecting stepper motors.
The maximum current that fans can draw depends on the fan voltage, and how it is being powered.
See also Connecting and configuring fans.
The CAN-FD bus provides connectivity to compatible devices. Duet3D manufactures a range of expansion devices.
The CAN-FD bus is connected via a 2-pin KK connector. 2-core twisted pair wiring is recommended.
There are two 60R bus termination resistors fitted to the CAN-FD bus on Mini 5+ boards, so normally this board must be at the end of the CAN bus.
If the board needs to be on the CAN bus between other boards, the CAN bus termination resistors should be disconnected or removed. This is NOT required in normal operation. It is only required if a Mini 5+ board is to be used as an expansion board and not placed at the end of the bus but somewhere in between.
From board revision 1.03 and later, there are two drill-to-disconnect jumpers that allow the termination resistor to be disconnected.
To disconnect the termination resistors, use a small drill bit ~2mm by hand to carefully remove the connection between the two pads that is made with the ring of the copper between the pads. Do not drill all the way through the board, the copper layer is approx 70um thick (i.e. very thin!) once its removed test that the pads are actually disconnected by checking that there is no continuity between them with a voltmeter.
Both jumpers must be disconnected or connected. Do not do only one.
If in the future you want to add the termination resistor back into the circuit the jumper can be bridged with solder.
Board revisions earlier than v1.03 will require you to desolder the two termination resistors. You need to remove both resistors, marked on the PCB silkscreen as R96 and R97, located adjacent to the CAN pins.
See image on right, resistors highlighted red. Click image for larger version.
Both resistors must be removed to disable the CAN termination. Do not do only one.
To remove a 0402 component such as one of those resistors, we recommend using a soldering iron with a 45 degree bit just large enough to cover both pads of it. Put fresh solder on the bit and then apply it to the component for several seconds. Once the solder under the resistor has melted, the resistor will stick to the bit and can be lifted off.
NOTE: Removing these termination resistors will void the warranty!
The bootloader is in protected memory and should not need to be reprogrammed. If you do need to reprogram it, you will need a Windows PC running Atmel Studio, and a SWD programming tool. Suitable tools, in order of increasing price, include:
If using the Segger tool, see this Adafruit page for an overview of the process.
To connect the programmer to the Duet, you will need a SWD cable breakout board such as this one and a 6-pin JST ZH cable.
You will need to remove the bootloader protection by doing Erase Chip first and then setting USER_WORD_0.NVMCTRL_BOOTPROT to zero. After that you can program the bootloader binary into memory.
Wifi Only
Ethernet Only
Ethernet Only
WiFi revision is version 1.02, Ethernet revision is 1.02a
First prototype. RepRapFirmware 3.2 and later do not support this revision.
| 0 | yes | no | no | Can be used to connect a PanelDue |
| 1 | yes | no | yes | |
| 2 | yes | no | no | The standard firmware does not support this UART |
| 3 | no | yes | yes | |
| 4 | no | no | yes | |
| 5 | no | no | no | IO5_OUT is shared with PSON output |
| 6 | no | no | n/a | 3-pin connector, input only |
| 7 | no | no | n/a | 3-pin connector, input only |
